How to print the barcode of one specific entry ?
The “report” option shows all the barcodes on the sheet.
You can add barcode fields to your Ragic sheets that can represent entries using the entry’s URL, item number/code, IDs, etc. For more details, please refer to this video.
I have managed to add the barcode based on product S/N.
my question is how to print the specific entry barcode and not all the barcodes on the sheet.
( The video shows how to print all the barcodes )
In the label maker report’s style settings, you can select a filter field that allows you to apply a filter based on the selected field(s). You can then apply custom filtering conditions to print the barcode of a specific entry.
