I have a sheet embed in a website, it is not sorted at the moment, however users of the website can click on the column header to have the table sorted by that column.
We would like to sort it before hand, pre-sorted by last name then by first name. Also, we would like to disable the ability for users to be able to sort the embed sheet!
Hope you can help…
I have gone over the embedding process and have not seen anywhere an option to disable the sorting feature!
Now from my understanding if I were to sort my Ragic sheet on Ragic, I could save that view, for a pre-sorted version of the same sheet. But the question arises for me, how do I embed a saved view?
I thought it would be possible but when I check, only the raw embed shows any option for selection a shared view, however not sure why, but nothing present in that drop down, so I could not test.
Specifically, I was wanting to embed the Database Viewer, and there is no option for selecting a shared view.
So how do I go about pre-sorting an embed sheet?
And can I turn off the sorting capability of embed sheets for website users?
Thanks a lot,
Kane
