Hi There,
I’m trying to connect Ragic to Docupilot via Zapier.
I manage to get into the API provided the API Key, and server name ragic.com
then when I hit next page, it come up with Which sheet do you want to use? and the list is empty. what to do?
Please advise.
Regards Raymond
Hi Raymond,
When you sign in Ragic on the Zapier, server name should be filled like below, it should be complete complete server location. For instance, if the URL to your database is na3.ragic.com/accountname, server name should be na3.ragic.com.
Hi Hank,
Thanks, I tried, but it gives me this error.
Hi, please try “ap7.ragic.com”
This is exactly what I filled in “ap7.ragic.com” and that’s the error I got.
Hi, It seems the server name had been filled with “www.ap7.ragic.com”, please try “ap7.ragic.com”.
