Hi this may be a topic for google docs developers but I assume this is a problem that those who tries to integrate ragic with spreadsheet will face eventually so here it goes.
How can you force spreadsheet to refresh more often?
I wanna share our data on ragic with our contracter through spreadsheet and let them fill in their data there but it is not practical with default re-calculating schedule.
How often the data are retrieved is totally decided by Google Sheet, there’s pretty much nothing we can do on our side. According to some online documentation, the interval is one hour.
You can actually write a Javascript inside your google sheet to pull data from Ragic. Then set a trigger on how often you want to sync it either every minute, hour, day. You may need an API key to achieve this.
