It looks like you can’t hide a description field - is this right? When I click on it, the editing bar on the left only shows options for Content, format, column span and styles; none of the options for typical fields.
Am I missing something?
It’s not supported to hide the description field since you can simply delete it if you don’t need it. May we have your use case on this?
Thanks! I actually hadn’t thought of deleting it, but it will work!
Kevin
