It shows that “Please select a Start Date field and a End Date field.”
But I don’t find the column for “End Date field”.
Would you please first check if you have at least two date fields designed in your source sheet?
There is no two date fields in my current sheet:
I tried to add another, but there is no another date field in the Available Fields.
It looks like you only have one date field. Please kindly note that you’ll need to have at least two date fields in order to set up the Gantt report.
If you simply want to mark the “Reported Date”, you may use the calendar report instead.
