Hi just gretting used to difference between Ragic and Excel…
I’m looking for the correct formula that would check the contents of a field and count the matching records.
in excel i would use a reference to check that cell against a range, for example…
=COUNTIFS($V$2:$V$173,"="&V2,$AC$2:$AC$173,"="&AC2)
so this would check the amount of matching records where the record V and AC2 matched identical records…
Any help would be greatly appreciated
