I have a subtable that has items of yes or no. If all items are yes, then on another cell, I want it to show up as Yes. If one is missing or has a no, I want it to be say no. This would be in the Level 1 - Fundamentals area.
Here are three formula types you would have to use in your “Level 1 - Fundamentals” field.
- COUNT(): Count the number of subtable entries in a subtable.
- COUNTIF(): Count the number of subtable entries with the “Yes” value.
- Conditional IF(): Check if the values returned from the COUNT() formula and the COUNTIF() formula are equal. If they are equal, that means all subtable entries have the “Yes” value.
