Today, I find the formula doesn’t work with the % calculation on the sheet which works well before. I don’t modify the formula. Do you have the same issue?
I’ve reported this issue to our developers and will keep you posted once the issue fixed.
We’re sorry for the inconvenience that may occur to you and your team.
We have just applied a fix on this issue that you reported. Please test it out and see if they are working as expected now.
Just test my forms, it works. Thanks for your quick response.
