I have a subtable on my form where each row hold various values relating to a specific year.
Each row (year) needs to house formula columns which reference and use values from the previous years record. They in turn being used as part of the calculation in next years values.
Sorry, my bad terminology. That should have said ‘previous’ not ‘last’. In your example I need to see the previous value for B in the current row. So every row that is added looks up the previous rows value for B.
As I mentioned in a previous reply that doesn’t work. See screenshot. C does not provide me with the previous Row value of B after the second row. I don’t want the running balance. Based on the screenshot the values for C should be 0, 100, 150, 200
