Hi guys,
I have a suggestion for a new feature.
I was just now trying to filter the data in one of my sheets, such that I would have liked to be able to filter according to one specific field,… all the records where data was present in said field.
However, I could not do it. If you can help let me know!
Thanks,
Kane
Hi Kane,
Please use the Filtering feature on the left side of the form. Set the specific field to “not empty” to display data in the form where that field contains data.
If this solution doesn’t address your issue, please provide the following information:
- Detailed description of your requirement and use case.
- Screenshots of your design and form interface.
With this information, we’ll be better equipped to understand your situation and provide you with the best advice.
Thank you.
