I wanted to know if you can have the possibility of filtering or searching the data by operators such as greater or less than … or a range of numbers or dates.
This function is very useful and important to search for example range of dates in invoices or amounts, for my work it is essential.
Only numeric fields and date fields support this type of search. For the test of field types, the values are stored as free text. Hence, they don’t work with numeric logic like less than or greater than.
