When something changes/goes wrong with an existing reference embed how can you tell the field used for the linkage?
Maybe you can add info to this screen.
Would the data dictionary tell us maybe?
Thanks
Thanks
Not quite sure what you mean. Do you mean how you recognize the linked field of a “show references from existing sheet” subtable?
Correct how do I know which field is being used to link the sheets?
Thanks
We will discuss this with our team and see if we can add some more info on this page to make the configuration clearer.
