Is it possible to exempt System Admins from the mandatory field requirement in entries (i.e. those with the “Not empty” box ticked on the design mode back end and the red asterisk)? I would like to leave it so that ordinary users and external users are still required to fill in those fields, but System Admins don’t have to. Please let me know if there is a way to do this. Thanks in advance for your help!
Currently, what you’ve described is not supported in Ragic.
The alternative way is through multiple version. You can create another version for SYSAdmin only and remove the feature of “Not Empty”. Then, for regular users, they can create entries in the original version while SYSAdmin creates entries in the new version.
Ok, thanks for letting me know.
Thank you for the tip! I will use this when I am testing things out
