I would like to download the 312 records recorded in Ragic, but the message “Exceeded memory usage limit.” appears and I am unable to download them all at once. Please let us know how could I solve this problem. Thank you.
Mass run mail merge to excel will take up much memory in use.
If data output exceed the limit to server memory, the mail merge job will be discontinued.
The limit will be decided by data volume, amount of fields, amount of images, etc.
On a conservative estimate, we would suggest mail merging 300 records at a time to avoid memory issue. Or maybe you can wait for a while to see if the flow decreased.
