If you create an empty multi select like this.
It does not allow the user to add an item.
Not a major issue as you can create an example item for the user but just letting you know.
Thanks
Thanks
Hi Stephen,
Thank you for your information. Looks like the issue occurs when no selections defined in multi-select field in the beginning. I’ve reported this issue to our development team and will notify you once it’s fixed.
Hi Stephen,
We have applied a fixed on this issue today. Please let us know if you have any further questions.
