Hi Ragic, I need some advice here.
I have this info into a list and create a form from subtable. I would like the selection in my subtable form to list down the selection based on the parent list.
If you would like your subtable field’s selection to be based on another sheet (parent sheet), you may consider setting up a link & load relationship.
If the above information is not what you are looking for, feel free to send us your issue and its related details to support@ragic.com. Information such as detailed descriptions of your data, details of your ideal workflow, and some data examples would definitely help.
