How to disable dynamic filter from UI?
Or how to retrieve set of records based on FK in the other sheet?
To disable dynamic filter when choosing record in the pop-up window, you could choose the option “clear filter” on the top right corner.
If you would like to disable the whole setting of dynamic filter, you can remove this on the same UI set up dynamic filter, there’s a x icon on the right side.
