I am a new user and have created two sheets. When creating initially, the sheet is in List view, then I can move the fields around to create my desired Form look. However, now when I open the sheets, each has changed to a “subtable look”; all fields are horizontal with multiple entry fields underneath. Just a few fields are displayed and the Field Picker pops up if I want add more. This is locked and I cannot move anything around. What happened and how do I change back?
Hello, it sounds like you might be on the listing page as opposed to the form page. They are two different levels of the same sheet. Please check out this video to learn more: https://youtu.be/oajx8CGQehA?si=8QzI_Swr7QdkvOdx&t=121
