Default currency
Hello,
I am trying to find a way (if possible) to set or change the default currency from Dollars to AED. Ideally, I would like to change current existing sheets and future sheets automatically. Is there a way?
Thank you
Hi there,
This is Kate from Ragic Support. Hope all is well.
Ragic is a highly flexible no-code database platform, which means it doesn’t enforce a fixed default currency setting like traditional systems. Instead, you have full control over how you define and display currency fields. For example, if you prefer to use AED instead of USD, you can simply rename your currency-related fields to indicate the desired currency — there’s no need to set this in a global configuration.
For both existing and future sheets, you can enter design mode and customize numeric fields—whether they’re of type numeric or money—to suit your needs. You can name these fields to reflect the currency they represent (e.g. “Amount (AED)”).
If you’re managing multiple currencies, Ragic makes it easy to set up separate currency fields and use formulas along with exchange rate fields to handle conversions effortlessly. Managing foreign exchange becomes simple and fully customizable. For examples and setup suggestions, check out this guide:
:point_right: How to manage multiple currencies
Hope this helps!
