Another simple and easy question for you!
In Europe, as you know, we do not use decimal points but decimal commas…
Couldn’t find where you can change this!
Thanks
(P.S. importing is very simple)
Thanks
This can be changed in the custom formatting on the numeric field. On the other hand, you may also select the default thousand and decimal separators in your company settings page.
Hi Fabio, I use the trial (free) version of Ragic and none of these methods seem to be working! At least the custom formatting should be!
Could you please provide us with screenshots of your numeric field settings and the incorrect value result for us to refer to?
Alternatively, if you would like to get in touch with us privately, you may submit a support ticket via the “Need Help?” button located on the top right corner of your database and provide us with the necessary details so we can help.
