Data not being saved while it’s mandatory to fill the field
Please start by confirming whether your Field Types is correctly set to “Date.”
If it’s indeed configured as a “Date” field, could you kindly elaborate on your method of data entry? For example, are you manually inputting the data or utilizing Action Buttons?
Providing a detailed explanation of your process will help us gain a better understanding of your situation.
