Hope someone can advise, bit difficult to explain so will try and make it clear as possible.
So I use Ragic for PM work, and I have one main worksheet which I use as my master work list sheet, and what I would like to have is when I create a new job in the master work list to be able to select from a selection drop down which phase of works this jobs is applicable to. Then once selected, this entry / job then duplicates automatically onto a separate sheet which is for phase 1 works, to help categorising the works, is this possible?
Thanks in advance everyone.
I don’t see how it will do, if I create a job in my Master Worklist, and when creating that job I enter all the data needed and I select phase 2 works for example, it won’t automatically add that job to both the Master Worklist sheet and the Phase 2 Worklist Sheet would it…?
Multiple versions share same data source, once you add a new entry on version A, it would also shows on version B and modifying entries would be reflected on each sheet.
Assuming Mater Worklist and Phase 2 Worklist are multiple versions, if not, please see link above and create one. Then you could try it out.
