Thanks.
Previously this kind of usage with 2 or more embedded report is interrupted because of the limit on concurrent report generation.
Looking forward to see if sequential generation of reports or custom sizing of report is possible.
Thanks.
As for now, you may apply the text wrap setting to the text homepage section.
Thanks @fabio — however wrapping static text is hardly a dashboard.
Is / Does ragic have any suggestions to a quick connector / 3rd party dashboard tool?
We don’t have a suggested 3rd party dashboard tool from our end. If you find one that meets your requirements, you may integrate the tool with your Ragic database using API integration.
