How do I create tags for the forum?
Not sure what you mean.
Please kindly elaborate more on your issue.
in this support forum, if i create a new topic, i have the option of choosing a category and a tag. But there are almost no tags to choose from. There are 5, four in some Asian characters. How do I create new tags?
It is not supported to add tags in the Ragic Community for normal users.
You may use category / hashtag instead.
so can you create some tags that we can use or remove the option?
We now enabled basic users to create tags, please see if you can create tags now.
Thanks,
Jeff
yes thanks
