I want to create approximately 8 distinct sheets to do the job with my 15-people team. I should note that i am the only SYSadmin and the others are just users. According to pricing plans i need the professional plan. The question is can I buy the professional plan once, only for me, and invite the rest of people with the free version to work on it by adding and modifying entries? Or will this different plan strategy block the free users from adding and modifying entries?
Thank you for your time.
If you need more than 5 custom sheets in your database, please select Ragic’s professional plan. On the other hand, all internal users in your Ragic database must be using the same plan no matter if they are or aren’t SYSAdmins in your database. Basically, Ragic’s monthly database subscription fee would be the number of internal user accounts multiplied by the selected plan’s price.
