Thanks for your post! While Ragic currently doesn’t support tracking the number of reminder emails sent as a field value, there are still ways to coordinate reminder logic that may suit your needs.
For example, using a conditional formula together with reminders based on shared views can give you more control over when and for which records reminders are sent. This approach can help create logic similar to an email count, even without directly tracking the number of emails sent.
If you’re able to share a bit more about your specific use case—for instance, the kind of reminders you’re sending and under what conditions—it’ll help us suggest a more tailored setup that works within your plan limitations.
