If I wanted to give another Ragic user with their own separate Ragic account a copy of one of my template designs, how would I do that without losing all the template settings like validations and comments and design elements like labels? I can of course export and import the sheet but then I’m only transferring field names and basic data types and losing all of the design elements. Thanks!
Moving sheets between different databases accounts is a feature that’s still in developing progress. Currently we’d suggest to use Backup and Restore to transfer sheets to another database, and manually delete the ones that you don’t need.
Regards,
Celia
