Hello,
I have data (logs) related to many categories. If I consolidate this to a single place, then how Ragic performance would respond to maintain high volume of data.
Roughly how many records count or size of data set does Ragic supports well without any performance downtime ?
Hi, your database performance will be based on a lot of factors, including number of records, number of fields, number of records per page, and the type of query that you’re running. Generally it’s the best to test them and find out. If you have less than 1 million records, usually you have nothing to worry about.
