Is there any way to use conditional formatting on a listing using criteria from fields that are in the sheet, but not showing on the listing? I tried removing some fields (columns) in a listing to make the listing smaller, but then the conditional formatting disappeared. That is the only reason why I have some columns showing on the listing.
If you would like to apply conditional formatting in the listing page, it’s necessary to put those criteria fields in the listing page as well. However, you can feel free to apply hidden feature for those fields.
