Currently the closest to this seems to be:-
Last Update | Is After | a Chosen Date.
It would be helpful to also have:-
Last Update | Is After | x Minutes Ago
Doable?
Doable?
It’s not supported under current structure, it needs to count every single minute, it might be a heavy loading to system.
How about instead an option highlighting each update for x minutes? i.e. any update is automatically highlighted, and starts a jscript timer for x mins then unhighlights.
