Conditional Format Selection in Alphabetical Order
When you have a sheet with many fields it is very hard to find what you need as the list are not in alphabetical order. Please, could this be applied in Ragic for all field selections?
Thanks a ton
The field order in the drop-down list is according to your form design, from left to right and from top to bottom. Changing it to alphabetical order would lead to a little bit of confusion since some of the users will have multiple fields with the same field name. It would hard for them to recognize which is the correct one.
