It would be great if I could set the color of the load bar to match company colors.
Not quite sure which load bar you mean, would you mind sharing an example with us?
Thx for your reply. The blue load bar on the splash screen when I go from one page to another, I can add my company logo which is red, it would be great to be able change it from blue to red.
