Please add the ability to select colours other than grey for the bubble color around selections in Single or especially Multiple Select fields.
We’re using selections in a Multiple Select field to tag records with characteristics (e.g. budget year, department, etc.). Because all selections have the same bubble color, it’s difficult to review a table column with a bunch of selections for each record to confirm that a particular selection has been applied.
Airtable manages this quite nicely with separate, user-selectable colours for each selection. I can review a column/field for a table of records in seconds, because I’m looking to confirm they’ve all got “the green one” included.
