Can't find "iframe sources" setting in company settings
As the title says. Documentation for unblocking iframe sources says to go to “iframe sources” setting in company settings but it’s not there. i’ve looked in almost every other db setting place I could think of, and I tried the find text function to make sure i wasn’t just overlooking it.
I would like to add batchgeo.com as a trusted source for map iframes.
You may need to update your system sheets if you don’t see the field.
Please send a support ticket and our support staff will help you with the update.
Thanks, support was able to update my sheet and everything works now. Can mark as closed.
