Calculate Function for Subtables
It would be great to be able to have the calculate function on subtables in the form view. We have many uses for this in our daily workflow.
Thanks!
Since we do support formulas in the subtables, would you mind to elaborate more on the calculation you would like to perform in the subtables? An example would be pretty helpful.
My apologies. I am referring to the calculate function that is already in place on the list view at the bottom:
Calculation for number fields in subtables is now supported. You should see a calculation icon at the bottom-left corner of the subtable.
Please give it a try. Thank you.
