Not quite sure that you mean but it’s supported to use string formulas to construct a BBCode. For example:
Note: A4 would the field that contains the link.
If this is not what you’re looking for, please share an actual example for us to refer to.
Thanks I tried that but it does not seem to work. "[url=https://www.test.com/search/results/all/?keywords="+A3+"&origin=GLOBAL_SEARCH_HEADER]Click[/url]"
