I want to create an autogenerated field to number the entries consecutively without breaks.
This is independently of the autogenerated field ID and it’s used to number the activates of a project.
The next entry should follow the previous one, disregarding any deletions.
Example:
I have 3 records with their entries numbered:
01, 02, 03
If the last record is deleted, the sequence is broken.
Lets say I delete 03 above, the next entry will be 04, when it should be as per my requirements 03.
So…
original sequence for this field is 01, 02, 03
delete last entry 03 (this case only happens if a user enters wrong data and deletes the record)
Next sequence is 01, 02, 04 when I need it to be 01, 02, 03 (new record should continue counting from previous one).
Is there a way to solve this?
