Has anyone created a successful appointment/booking form on Ragic? If so, can I see it? Thanks.
We do have reservation system, you could install and give it a try, which please refer to this document.
So awesome! Thanks! Now is there a way to prevent someone from scheduling more than (as an example) 2 hours a day?
Currently, it is not supported.
May we know your scenario for our reference?
Yes, essentially, we don’t want people using the “space” more than two hours a day to give others the opportunity to use it as well, so we want to limit 2 hours per person per day.
Thanks for the reply.
We do not support this setting, but we’ve collected your suggestions. If multiple users suggest this feature, we’ll evaluate it.
