Hi ragic member, i am here to ask regarding applying formula on subtable.
the formula that I apply is SUM(B9) where it sums up all the B9 column. But I am wishing to apply formula for that particular subtable only instead of the whole column.
If you want to summarize a field in subtable, you can apply “B9” directly. Furthermore, the free text field type cannot be summarized, please change it to the numeric field type.
If you still have the issue after above adjustment, please send us a ticket via the “Need Help?” at the upper right corner of your database so that we could have a look at your sheet design.
