I was wondering if it would be possible to get a “Recommended Not Empty” option for fields. There are fields that are considered high priority, and shouldn’t be empty, but there are also times when not being able to save the record without completing it is not desired.
So I wondered if there could be the possibility of a pop up saying something along the lines of: “Field X is blank- are you sure you wish to save with this field blank?”
That way it is not going to be forgotten, but people also won’t lose all the work they have done completing the record if they just an’t fill in that one field yet.
Thanks,
Terri
