Hi There,
Would like to Add 3 field into 1 field. A4 +’ ’ +A5 +’ ’ +A6
however, if A5 is empty, it will create additional space in between A4 and A6.
Anyway that if A5 is empty, it will not create a space?
Thanks in advance.
Regards
Raymond
Hi There,
Thanks in advance.
Regards
Raymond
Hi Raymond,
I think I follow what it is you would like to do here!
Try: A4+IF(A4=’’,’’,’ ‘)+A5+IF(A5=’’,’’,’ ‘)+A6+IF(A6=’’,’’,’ ')
Hi Kanefranco,
Thanks but I tried the formula seems to have an error, saying that formula is not correct.
Regards
Raymond
You could try this out, IF(A5.RAW=’’,A4+’ ‘+A6,A4+’ ‘+A5+’ '+A6)
When to add .RAW, please refer to this article:
Thanks All,
I managed to get it right and here is the formula.
IF(A6.RAW=’’,’’,A6+" “)+IF(A7.RAW=’’,’’,A7+” “)+IF(A8.RAW=’’,’’,A8+” ")+IF(A9.RAW=’’,’’,A9)
Cheers
Raymond
