Hi everyone,
I’m working with Ragic and have run into an issue related to Access Rights when retrieving data through the API.
Here’s the situation:
I’ve set the sheet’s Access Rights to “Survey User and User Group as the entry’s owner,” which allows users to see or edit only the entries assigned to them.
When using the web panel, everything works fine MyUser can see and edit its own records as expected.
However, when I try to retrieve records using the API, MyUser can’t see any records.
Interestingly, if I change the Access Rights to “Everyone as Viewer,” MyUser can see all records via the API (which isn’t what I want).
A few details about my setup:
- I’m using React with Axios for the API requests.
- My API request includes the correct
sessionidfor MyUser, which I’ve verified. - The request URL follows the Ragic API documentation for fetching records from the specific sheet.
Could someone please tell me what I might be doing wrong? Do I need to configure something additional to make the “Survey User and User Group” access setting work correctly for API requests?
Any help or pointers would be greatly appreciated!
My settings details are from the web panel.
Thank you
Cezar Souza
