- How do I delete an uploaded template?
- I can’t figure out how to indicate which field in this popup. All there is is a check box.
You could see the “Delete” option after clicking “Edit the Template”.
Only when there’s a file upload field on your sheet, you would see the field name shown in export option.
Thanks.
