Hi Amy, I got it already~
This trash icon only appear after I saved the entry~~~
but during I key in the entries, there is no trash icon.
I just wondering, could the mobile app has the same remove button as the web ragic to remove any entries during key in.
This is because, sometimes we may key in the wrong entries in the subtable, and we may have realized the error and quickly wanna remove the entries in the subtable before saving.
Just like the web ragic, it is good~
This is just my suggestion and hope it can be enhanced on this feature.
It’s currently not supported to edit or delete the subtable records on entry form page while using mobile app, you will need to click into one subtable entry to do it.
Hello, I have a similar problem. I can correctly visualize the trash bin but when I press it, a circle appears that spins forever. (No internet connection problems). Some advice?
We didn’t reproduce this problem, would you mind log out and log in again to see if it works as expected? Is it happened to all sheets in database or a specific sheet?
If not, please send a ticket via “Support Help”, it’s on the upper right corner of your database page in browser side with the problem and issue URL and allow Ragic Support to access to your database for testing.
