sorting subtables by drag and drop to a different position
Since I’m not quite sure about what you mean, do you mind sharing some detailed information for us to refer to?
Thanks!
in a long subtable
I would like to change the position on row 20 to row 11 (for example)
by dragging it up
You may refer to this article for sorting your subtable entries.
And it’s not supported to change the entry saved order.
this is why i put it in feature request
OK. We will keep track of this feature request and see if we can implement this in the future releases.
thanks!!!
