I used the create custom email tool to generate an email from a form and with it I select Include PDF file of this record. It worked just fine for months. Now suddenly, rather than send a pdf of the record it creates and sends a blank pdf that says only Ragic logo up top and Sign in with Google at the bottom. Is there a RAGIC defect of late? I don’t recall changing anything that would cause this.
We have just applied a fix on this issue. Could you test it now and see if this problem has been solved?
Thank you.
Hi, same result. Doesn’t work.
hi are you still working on this?
works now thanks
