Hi there,
I would like to design a report with data from one master sheet and linked data from a subsheet. this works already fine with the forms, but how can I do it with reports?
thx!
Hi there,
thx!
Currently, reports can only be generated based on the stand-alone field instead of subtable. Hence, you may need to use new sheet from subtable first. Then, generate the report based on the newly created sheet.
