Is there a possibilty to create a “Quick” add button with for example prompt(); i cant find a way to add quickadd to subtables.
Workflow would be something like this.
- Click button Quick add and fill prompt message
- Create new entry in table with information of the quick add user, the message, the current date time.
And could you explain how “insertAPIEntry” Works, there is no example in your manual.
Greetings Gijs
