PDF Preview for Custom Print Report and Print Function
There should be a feature where the user can preview the Custom Print Report for PDF output. The feature should also capable for printing the PDF while in preview. The existing functionality of the Custom Print Report is hassle since it will download the PDF before I can print it. After printing, the PDF is occupying storage to my computer unit and needs to be cleared.
Thanks for the feedback! Good news — this is already supported today. Custom Print Report has a “Use print preview instead of direct download” option under Advanced Setting → PDF Settings. Once enabled, the report button opens a preview window where you can print directly, without downloading the file first.
You can find the setup steps here: Custom Print Report – Advanced Setting > Use print preview instead of direct download
